AsRock 775 DUAL-VSTA & Core 2 Duo E6400 - big Problem
5 Feb 2007
I recently did a cheap upgrade to Core 2 Duo (6400) using the AsRock 775 DUAL-VSTA. Everything worked sweet as a nut with absolutely no problems for about 1 week or so. In the middle of the night while I was asleep the machine (which is left on), just started restarting, and never stopped.
It gets past the memory test, and has located all the drives etc. when it flicks to start booting the OS, it just resets. I can clearly hear the little click noise from the board, the same noise that occurs when I hit the reset button.
I have removed, swapped, and tried less of the memory modules, and it makes no difference whatsoever.
I have swapped out various Hard drives with different OS's, and it makes no difference. It will not boot from a windows CD, or indeed a boot floppy.
I can get into the Bios as normal, but I don't get the menu choice to boot into safe mode.
I have tried cleaning and reseating all components, and tried it without all components it doesnt need. No good.
The case is very cool as is the CPU temp, plus I underclocked the CPU just in case, so its not that.
Deducing it must be the motherboard, I RMA'd the mortheboard back to the retailer, they tested it, said it was faulty and a week later I received my replacement. I installed it and guess what........
It didn't work! The PC still reboots itself immediately after the memory and drive check. While my motherboard was back with the retailer, I reinstalled my old motherboard and CPU, and everything worked perfectly, albeit slower with the old CPU.
Is it possible it could be the new CORE 2 DUO (E6400) CPU. The BIOS still reports that it is running nice and cool. Would it even get to the BIOS if the CPU was faulty?
If anyone has any ideas, I would really appreciate them.
thank you
flares
Intel Core 2 Duo E6400 (allendale)
ASROCK 775DUAL-VSTA
1GB PC2700 RAM (2x512)
ATI Radeon 9800 Pro
Windows XP Pro SP2
Is the e6400 at stock speeds?
Tbh I wouldn't fancy trying to run a 266mhz fsb Intel cpu with 333mhz DDR RAM. Try to get your hands on some dirt cheap pc2-4200.
Hi - yes its at totally stock speed. It ran sweet for a week or so, but now won't get to OS anymore. Could the RAM cause such a thing?
Do you know anyone else with a C2D motherboard that you can test your CPU in? I doubt its a memory compatibility problem as a lot of people are running various speed DDR memory with this board without problems.
Try testing the CPU or borrowing some DDR2 from a friend if you can. How long has it been since you bought the CPU?
I don't know anyone else with a Core 2 DUO mobo. I have had the CPU for about 1 month. Can anyone tell me, if the CPU was faulty, would the machine not startup at all. The reason I ask is that I can still get into the BIOS.
flares
flares
Well Icracked a core once on a cpu and that wouldn't boot. Must have been a hairline crack because you just could not see it :( No bios either )
thank you
flares
ASROCK 775DUAL-VSTA
ATI Radeon 9800 Pro
Windows XP Pro SP2
Well I’ve got a confession... my computer behaved like this and i eventually removed the MOB and tested outside of the case (worked fine).... I discovered I’d left an old MOB pillar mount that was not lined up to anything else!.... could have ****ed it but it didn’t!... strange thing it only started acting up after an hour of install ...including a re install of XP!... WTF! :eek:
If you can get it to start loading the os hit F8 key & try booting into safe mode.
If this works you could then try a system restore.
To be honest you have got to try everything that has been suggested and everything you could possibly think of. Personally I would try your motherboard with somebody elses cd2 cpu and power supply: and if that booots ok you'll be one step closer to isolating the prob. I am sure a shop would do this for when they had a moment and for a nominal fee. Good luck :) Sounds like a power supply or short problem on the mobo 2 me and it is not entirely inconceivable that you have been supplied with a faulty batch of mobos?
