ASrock 939S56M temperature monitoring software
18 Oct 2002
Maidenhead
Has anyone got this board? If so, have you found any temperature monitoring software which works?
Ta
From when I last used it(albeit on a socket 478 system) I seem to think it was Probe 1, generally it should be the higher of the two, as the lower will usually be the motherboard chipset itself. You can always check your CPU temperatures in bios.
