Ok I purchased the ASRock 970 Extreme4 on Sunday.
AMD Piledriver FX-6 Six Core 6350 Black Edition 3.90GHz (Socket AM3+) Processor - Retail £85.74 1 £85.74
ASRock 970 Extreme4 AMD 970 (Socket AM3+) DDR3 ATX Motherboard £65.33 1 £65.33
XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £40.83 1 £40.83
TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34096M1600HC11DC) £24.49 1 £24.49
I put all this together and tested it with the RAm and CPU installed and it booted fine. I then added the rest in untill i am at the final product. P
Problem is all cables are connected in the correct places and i have reseated the RAM and when I place the power plug in the PSU about a few seconds pass the MB starts and all fans on case and CPU start to spin for about 3-5 seconds then all power just cuts out. There is power to the MB as the onboard power and reset button are lit. I can't reset it pushing the buttons on board or case. I have to disconnect power and wait for the power to drain after holding the power button. I have tried resetting the CMOS both via the button on the back of the MB and the jumper switch. Once i connect the power it does the same again and again. I have tried removing the HDD, GPU, Optical Drive but still no luck. I haven't even got to install OS yet
I have referred to the Dr. Debug but the code that comes up is not in the book. The code i get is flashes really quickly and is along the lines of 26 - 36 - C7 then power goes off.
