- 1 Sep 2013
Hi, I’m planning a MATX build, iv gone for a fx 8350 which has a tdp of 125w, the only micro atx motherboard I could find was the asrock 970m pro3, which has a tdp of 140w which seems sufficient for the 8350, the only thing concerning me is hearing about the “VRMs” on the board getting hot and killing the board or causing throttling, I’m going to run it at the stock no overclocking , the case I’ve chosen has two front intake 120mms and iv got a cooler master hyper 212 evo in push/pull as the cpu cooler as well as an exhaust at the back of the case , is it as bad as they say or will the motherboard be fine ? Many thanks
Also the reason for old parts is budget building off of eBay , I already have everything apart from this motherboard , and it’s arriving tommorow , so a new part list is out of the question
