ASrock B360 Pro4 - No Sound from front ports
15 Mar 2004
Oxford
Hello,
I made a pc for my step son in February.
He has a Y splitter plugged into the front ports on his Kolink RGB Midi Tower for his head set to go into. (its a ps4 / xbox headset so one Jack hence the splitter)
When i was swapping with an identical headset tonight, the front ports have stopped working.
I reset the pc, unplugged the front audio from the motherboard, re plugged it in. Still nothing. Now windows does not even recognized anything is plugged in to the mic or the speakers.
The sound is fine on both headsets if plugged into the ports on the back of the motherboard via the splitter. The usb and everything else is fine on the front panel of the case just the audio......
Any ideas ?
So i went into the bios and changed the sound from HD to AC 97 and now they work. However i can’t get the rear output to stop playing when the front in plugged in
