Can anyone who has this board advise me how they connected the their case power cables to the board's System Panel Header? My case's Power LED requires 3 pins (middle is blank) yet the board only provides space for 2.
You convert the 3 pin plug into a 2 pin one.
Basically you move one of the pins to the emplty middle hole and then cut off the now useless empty outside one. This gives you a 2 pin plug.
