Asrock Dual939 SATA2 Onboard Audio Buzzing?
7 Aug 2006
Hi all,
Just a quick question. I am using the onboard audio on my Asrock Dual939 Board with AM2 CPU board, and basically, whenever I scroll down the page in IE and other applications, I get a buzzing sound from my speakers.
The issue occurs whenever I use my mouse in certain ways, and stops as soon as I stop using it.
I am using Xp pro 32bit if it helps anyone! Just thought it might be a known problem or the solution be known?
Many thanks,
Horror
