ASRock Extream4 Gen3 I5 OC Switching between 41/42/44/46
20 Jul 2005
Earth
Questions are below the spam!
Hey, I've had this system what appears stable but then not so.
Originally using the Auto OC, either at 4.4 or 4.6, Both seemed ok but volts were a bit high, I've tryed manual OC but there are a few settings im unsure of. After hours/days of use random BSOD, not during stress testing tho. (note I get random BSOD on auto oc as well)
From memory BSOD were something like theses two
A core has missed an interval (which i read could be related to too low volts)
and IRQ_something_something_something.
Current OC is manual 46, Offset -0.10, Which = min0.98v max 1.37
46, Offset +0.10 gives me Min 1.xx(ish)v max 1.39 (which i actually think is 1.384)
Speedstep On, and CPU LLC set to level1
Questions!
I'm wanting a better understanding of things more than anything,
#1 Whats Turbo Boost Power Limit, seems to be how much watts can be put thur the cpu at certain times. Theses are on 118 and 95 *standard settings*
#2 Current Core Limit 150, (something related to the thing above)
#3 (Why does this happen!) Currently, the system when running IBT, Goes up to 4600mhz, Drops down to 4200, 4100, 4400, and if im lucky shoots back up to 4600 just as the next test starts. Is the cpu reaching some kinda of wattage limit and getting held back, do i need to change something todo with the settings above?
Recently disabled the C3 and C6 (theses are from memory) reporting.
For awhile i thought it was speedstep, but running 20+ tests of IBT, the cpu seems to spend more time at 4200 than 4600. Temps rarely go above 60, maybe 63 at times, its in a antec 1200 so case cooling is more than enough.
Thanks for any help!
Main issue is #3,
Even when I OC to 4600, I just dont see it running at that very often, its always changing. If it was Only between 1600 and 4600 I wouldnt have a porblem, but why is it always moving in stages? and spend more time at 4200 when IBT/linx/prime or any program is pushing the cpu to 100% usage.
(3) is happening because of (1). The CPU is throttling down because you have non-OC power limits set. This used to happen on my 2500K system as well (also ASRock Extreme4), until I set that to manual, and changed both long and short duration power limits to 200.
Thanks, I'll do some testing see if that fixes some/all of the issues.
Your using offset for volts ye? assuming you have an offset of - volts?
