- 10 Apr 2004
I've now delidded my 8600K thanks to @Awahwah lending the tool out to forum members. Sadly I need to be AVX stable as Camera Raw (Lightroom) uses AVX and AVX2 in the rendering engine.
Net result is I can pass IBT for 10 loops using 8GB memory now without throttling due to one core dropping 30C(!) and on average 20C. (~200W load)
Board: ASRock Z370 Extreme 4
Memory: Corsair CMK16GX4M4A2133C13 Vengeance LPX 16 GB (2x8 GB).
Cooler: Noctua NH-D15 (Twin fan config)
Settings in the BIOS are:
CPU Multi: 48
Cache Multi: 40
Vcore: Dynamic +60mv
LLC: Level 1 (Highest)
VCCIO: 1.11V
VCCSA: 1.11V
Mem: 3200MHz, 15-17-17-34-540, 1.35V. (2 passes Memtest 86+)
CPU-Z/HWINFO shows Vcore of 1.41V but the multimeter on the PWM shows 1.49-1.50V(!).
Load temps are ~75C.
I'm now testing at 4.9Ghz (Prime95 non-AVX) with +70mv which shows 1.34V in CPU-Z and 1.41V on the multi-meter.
I'm slightly concerned at the differential between what the motherboard is reading Vcore to be and what it is actually being given.
So the question is (might be one for @8-Pack):
A) Are people giving their CPUs more V than they think?
B) People with 5GHz+ CPUs running 1.4+V Vcore, have you actually measured your physical Vcore?
The measurement points on a Asus Z77 board I have reads +-15mv of the CPU-Z reading, the ASRock Extreme4 is WAY off.
Thoughts??
CPU Multi: 48
Cache Multi: 40
VCCIO: 1.11V
VCCSA: 1.11V
Thoughts??
