- 11 Dec 2005
- Cheshire
Check this out! Asrock are really pulling out all the stops with the all new Fatal1ty Professional motherboard. With SLI and crossfire support and 16+2 phase power this board is an overclockers dream! A great alternative to the Maximus IV Extreme at a considerably lower price. Get yours now!
Asrock Fatal1ty Intel P67 (Socket 1155) DDR3 Motherboard @ £199.99 inc VAT
Introducing the Asrock Fatal1ty Professional Intel P67 motherboard is the pinnacle of gaming performance. Featuring a massive 16+2 phase layout allowing for ultra stable overclocks and enough power to fuel the most power hungry of overclocks. C.C.O., stands for Combo Cooler Option, is another exclusive hardware design on ASRock boards. C.C.O. provides the flexible options to adopt different CPU cooler types and matches your socket LGA775, LGA1155 / LGA1156 CPU cooler in the respective holes. Once again, ASRock has successfully expanded the utilization of PCB by the exclusive C.C.O. design.
Fatal1ty Mouse Port is a customizable technology for PC gamers that is a part of F-Stream. After plugging the USB mouse into the Fatal1ty Mouse Port and running F-Stream, gamers can use Fatal1ty’s personal preferred mouse polling rate at 500 Hz. F-Stream also provides the flexibility for gamers to adjust the mouse polling rate from 125 Hz to 1000 Hz. This is helpful for professional gamers to experience smoother game play and faster response time to the mouse. By adopting digital Pulse-width modulation (PWM), the Fatal1ty Series can provide CPU Vcore voltage more efficiently and smoothly. Compared to analog PWM, digital PWM can optimize the CPU power solution and provide a proper and stable Vcore for the processor. Fatal1ty XFast USB Technology redefines the new standard in high performance computing. Proving once again to be the pioneer in motherboard industry, Fatal1ty XFast USB Series Motherboards integrate with the latest XFast USB Technology which delivers the world's fastest USB data transfer speed. According to the below graph, it shows that the Fatal1ty XFast USB technology can even boost USB 3.0 performance up to 97.7%!
The Fatal1ty Series motherboard is designed with a V16+2 Power Phase, featuring sturdy components and completely smooth power delivery to the CPU. The P67 Professional Series offers unmatched overclocking capability and enhanced performance with the lowest temperatures for PC gaming enthusiasts. Coupled with six USB 3.0 and six SATA3 ports, the Fatal1ty motherboard offers plenty of storage options. Based on the concept of customization, this board is specially equipped with six USB 3.0 ports (two from external Front USB 3.0 panel, four from real I/O) and six SATA 3 connectors to satisfy PC DIYer’s various needs. All the capacitors on the Fatal1ty Series gaming motherboard are luxury, Premium Gold Caps. These 100% Japan-made solid capacitors are sleek, high gloss caps with a premium gold coating representing long life and stable performance.
- Support for Intel Core i3/i5/i7 Socket 1155 Unlocked CPUs
- Support for 1333/1600/1866/2133MHz Memory
- USB 3.0 and SATA 6GB/s
- 16+2 Phase Power for extreme overclocking
- Crossfire and SLI Support
- ATX Form Factor
- 3 Year Warranty
Only £199.99 inc VAT.
ORDER NOW
- ATX Form Factor
- 3 Year Warranty
ORDER NOW
