Asrock Flashback with CPU
26 May 2009
So, according to the manual my board's Flashback feature "allows you to update BIOS without powering on the system, even without CPU".
Anyone know if this mean that it can do it with or without a CPU installed, or only without a CPU installed?
Thanks.
In case anyone finds this in the future the answer is yes you can flash it with a CPU installed, the process doesn't boot the board or power on the CPU/etc.
