27 Sep 2009 at 15:22 #1 Shakeel Shakeel Soldato Joined 27 Sep 2009 Posts 2,780 Installed win 7 rc with an intel e6850. After the isntall completed i got a 'no input signal' i tried an intel e5200 as well but still no luck. is the motherboard dead. i also tried two monitors. 17" lcd and 24" lcd
27 Sep 2009 at 17:08 #2 RJC RJC Don Joined 29 May 2005 Posts 29,049 Location Kent Is this a completely new build or just an update. If a new build are all power connectors in including the 4 or 8 pin for cpu power, try only one memory stick and possibly try a CMOS reset.
27 Sep 2009 at 19:50 #3 Shakeel Shakeel Soldato OP Joined 27 Sep 2009 Posts 2,780 RJC said: Is this a completely new build or just an update. If a new build are all power connectors in including the 4 or 8 pin for cpu power, try only one memory stick and possibly try a CMOS reset. Click to expand... thank you for your reply. ive tried all of that
