Previous basic config:
ASRock P4i65G
P4 3 Ghz
2 x 1Gb DDR400 (CL3)
7300GT AGP
1 x SATA HDD/ WinXP
1 x E-IDE/Vista
1 x E-IDE/Storage
Pioneer burner
500W PSU
What I did:
Swapped mobo for a P4VM890
Swapped 7300GT for 8600GT
Added SATA HDD
What didn`t happen:
Windows wouldn`t boot from either drives in Normal/Safe
What I did to try and get out of it:
Removed all hardware except each HDD in turn ... no luck.
Tried different RAM (only 2 x 256 but compatible with board) ... naa.
Hooked up DVD drive, stuck in new SATA drive ... running note, altered BIOS correctly for each scenario ... clean installed XP, went spiffingly, tried full boot, bombed out again, then got to log in screen and NT Authority pop-up appeared and auto shutdown occured. Couldn`t even safe mode after that.
What I did next:
Whopped things back to the way they were yesterday. New and old Windows, regardless of which drive they are on boot up fine.
Additional:
Bios for both boards are pretty similar, though new one has Raid ability. I turned this off ... default is on so other than that, I eventually returned Bios settings to factory ... nowt worked!
Would really appreciate some help! I`m stumped, other than the obvious that the board is goosed. I`m thinking that there must be some setting somewhere in the Bios that I`m missing ... I only say this because a Google search with the board code + wont boot yields a multitude of disgruntled punters, surely not so many folk have a dodgy board?
Raised the issue with ASRock techies ... reply basically: RTFM Geordie, it doesn`t support Vista ... they must have missed the part where I said I clean installed XP on a brand new drive.
If no luck, I`ll send the board back, then I`m stuck with a PCI-E card and 2 gig of 184 pin RAM ... I thought of a skt775 bundle with a core duo but I can`t find a single board with these features that will support my RAM.
ASRock P4i65G
P4 3 Ghz
7300GT AGP
1 x SATA HDD/ WinXP
1 x E-IDE/Vista
1 x E-IDE/Storage
Pioneer burner
500W PSU
What I did:
Added SATA HDD
What didn`t happen:
What I did next:
Additional:
