AsRock P55 Pro Issue after cleaning
14 Feb 2023
West Yorkshire
Hi all,
So i clean out my pc every now and then to remove dust.
Today i unplugged the hard drive, removed the fans and graphics card and gave it all a good clean.
I did remove the power supply from the case but didnt unplug as i had access to clean the fan. Power to pc was unplugged.
After i switched it on, it came on, logging in sound for windows but then blank screen. First i thought i had messed up the graphics card. Held down the power button to switch off and then switched it back on. It came up with boot checksum error and let me go in to bios and reset to default after which all works fine. I have noticed on the motherboard it always used to have 39 lit up however now it shows AA even though the pc is working as normal.
What did i do wrong?
Motherboard is a asrock p55 pro.
10gb Ram
Intel i7 860
Gtx 770
