ASRock X570 Pro4/5800X3D and DDR4 memory?
26 Nov 2002
Oxford
Thinking of going from 2x8GB of Team Group 8Pack Edition 16GB (2x8GB) DDR4 PC4-25600C14 3200MHz Dual Channel Kit to 2x16GB memory modules in RGB
My Mobo -ASRock X570 Pro4 states it Supports up to DDR4 4066+ (OC) (although I'm not sure what this means) paired with a Ryzen 5800X3D
What would be the best value 2x16GB RGB memory modules to suit my Mobo and CPU?
Lexar Hades is the cheapest RGB ram I can see in stock (£90 for 32GB), is higher latency than what you have, but a faster speed, you pay £10 over the non-RGB ram.
Corsair have a similar RGB kit for £100 (supposedly Ryzen tuned), but it is pre-order.
The 8Pack kit (3600, C16) is £140, which seems like a lot, but I guess you're paying for Samsung B-die (and I think it is supposed to be dual rank too, which is getting kind of rare now Ballistix is EOL). Kingston Fury Renegade may be dual rank too, according to the datasheet of the model I looked at ( KF436C16RB1K2/32 ), but no RGB.
