- 23 Sep 2008
Hi,
I am having some issues with a new build:
Skylake 6600K
Asrock z170 gaming K6
Kingston Fury Black 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit
GTX 770
Built successfully, reinstalled windows, upgraded fresh to windows 10. I have been running fine for about 2 weeks, then suddenly BSOD and failed to boot.
Error code 60 on the motherboard, which searching about seems to relate to memory. I reset the CMOS and reseated the ram, booted fine. 2 days later, fail to boot, same error, reset CMOS, put ram into the other slots, Currently ok.
I have seen this issue with other ASROCK mobos and was wondering what could be causing this?? I have updated the BIOS, disabled power saving.
I keep thinking faulty RAM, but It appears on so many asrock mobos maybe I am doing something wrong?
If it happens again I will Underclock the ram to check that currently at auto settings its running at 2400.
Skylake 6600K
GTX 770
