Asrock Z68 Extreme 7 - RAID Issues
Permabanned
15 Dec 2008
I bought an Asrock Z68 Extreme 7 from the B-Grade section of OCUK and while it works amazingly well I can't get it to use RAID correctly.
On the board it replaced ( MSI Z68-GD80 ) I have 2x Mechanical HDD's running in RAID 0 for my STEAM and Origin installs.
Every time I moved to a different motherboard I've simply enabled RAID in BIOS and it's picked up the RAID array and loaded into Windows fine.
It's not the case for the Extreme 7 though! When I enable RAID it detects the array fine but crashes on Windows loading screen.
There's 2 options for storage in BIOS;
SATA and SATA 3 options, I've played with them both and nothing?
Is there something I'm missing?
I have this motherboard on a pc with raid 0 with 5 drives and it works fine
But then I did a clean install with all the drivers
