ASRock Z77 Pro4-M options
10 Apr 2013
Ive got pro4-m and a h100 refurb on order but im debating cancelling and going on air for a modest overclock of 'upto' 4.5 cooling and cpu dependent. Its housed in obsidian 350d. Im trying to keep the colour scheme all black and ive heard that coolers to heavy may warp the mobo. Im just after some cooler options and ideas before the h100 comes.
Cheers all.
Modern motherboards are made from good quality materials, and the big air coolers all utilise very sturdy brackets. Warping with theese coolers isnt a problem.
How are noc dh14 on this board, will it fit at all? Im using teamgroup elite ram and the first pcie slot is taken. Ive got a brand new pc built theres thats crying out to be broken in but the wait on this h100 is crippling. Argghh!
either stick with an all in one WC solution (See my sig) or go for a full atx extreme/pro 4 and a bigger case... all in all i think the noc d14 is pushing it for the 350d ?
