Assassins Creed Origins strange settings results
19 Jan 2010
Hi All,
So basically ive been messing around with the settings in AC Origins to find the best way to get a constant 60fps at 4k.
I can do it with a mix of between high and very high. The strange thing is that if i set the AA to low i get more FPS than if i was to set to off!!??
Im not an AA fan due to the amount of a performance hit i get at 4k but with this game it seems to lower performance by around 5fps if i switch this off....
Anyone else seeing this behavior?
Thanks
If I remember correctly enabling low AA in Origins or Odyssey actually reduces the render resolution then upscales back to the target resolution.
... not only AC Origins ;)
Metro LL Redux 4K SLI 1080Ti with average SSAA - 0.5x
I have well over !!! FPS :eek::D
and with SSAA - OFF 4K max is 100 - 120 FPS only :(:D
btw. Metro Last Light Redux in 1080TI SLI ( all settings ) will smash any single RTX including 2080Ti and new TITAN RTX as well.
This is nuts! Its being advertised as AA but its clearly not!
