- 20 Dec 2011
- Aberdeen
I have just gathered all the necessary bits and pieces (I believe) for a 'future proof' gaming PC for myself.
Could you please asses it for me and check if I have everything I need? I would also like to know if the power supply is sufficient as I have doubts.
I don't believe I will need to overclock anything or go crazy as I will really only be playing WoW with the odd dabble in other things like Skyrim.
The monitor and other bits and pieces I will buy separately.
Guts:
Processor: http://www.overclockers.co.uk/showproduct.php?prodid=CP-430-IN
Graphics Card: http://www.overclockers.co.uk/showproduct.php?prodid=GX-286-AS
Motherboard:http://www.overclockers.co.uk/showproduct.php?prodid=MB-391-GI
Hard Drive: http://www.overclockers.co.uk/showproduct.php?prodid=HD-366-WD
Power Supply: http://www.overclockers.co.uk/showproduct.php?prodid=CA-146-AN
RAM: http://www.overclockers.co.uk/showproduct.php?prodid=MY-114-GL
Heatsink: http://www.overclockers.co.uk/showproduct.php?prodid=SY-000-AN
Cooling Fans: 4x http://www.overclockers.co.uk/showproduct.php?prodid=FG-036-AK and 1x http://www.overclockers.co.uk/showproduct.php?prodid=FG-045-AK
Fan Clips: http://www.overclockers.co.uk/showproduct.php?prodid=FG-053-AK
Case:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-046-BX
PS: I am temporarily hijacking my boyfriends account as mine has yet to be approved. This is also my first time building a PC so if you do have better options for me please explain them like "X is better than Z because blah balh etc, etc."
It took me a long time to pick everything above because I read into them all and tried to find the best for me. I am trying to learn by myself (with some hints and tips from my boyfriend) so if you could take the time to explain things I would very much appreciate it!
Thanks!!
L
Guts:
Case:
Thanks!!
L
cool!
