Assistance needed- 580GT crashes
4 Sep 2013
Hi,
Recently put my 580 gtx in a new case. Changed nothing else- Only difference is that it's cooler.
Since- Formatting and installing BF3- I get the error below every time and cant play for more than 2 minutes.
Fault bucket , type 0
Event Name: LiveKernelEvent
Response: Not available
Cab Id: 0
Problem signature:
P1:
P2:
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
C:\Windows\LiveKernelReports\WATCHDOG\WD-20130908-1922.dmp
C:\Windows\Temp\WER-512884-0.sysdata.xml
C:\Windows\Temp\WERE06F.tmp.WERInternalMetadata.xm l
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\K ernel_0_0_cab_135be09e
Analysis symbol:
Rechecking for solution: 0
Report Id: a61a1945-18b3-11e3-b6ed-bcaec519f513
Report Status: 4
I;ve no clue what's caused this. Tried up to date drivers, wiped them clean. Tried everything that you'd initially go for and searched google. I've no clue.
Can anybody help,
Cheers.
Here is a WER report-
Version=1
EventType=BEX64
EventTime=130231240723520602
ReportType=2
Consent=1
UploadTime=130231240756942514
ReportIdentifier=d780ca10-1892-11e3-b17f-bcaec519f513
IntegratorReportIdentifier=d780ca0f-1892-11e3-b17f-bcaec519f513
Response.BucketId=3818023614
Response.BucketTable=5
Response.type=4
Response.CabId=-399277017
Sig[0].Name=Application Name
Sig[0].Value=nvstreamsvc.exe
Sig[1].Name=Application Version
Sig[1].Value=1.5.28.0
Sig[2].Name=Application Timestamp
Sig[2].Value=51f375bb
Sig[3].Name=Fault Module Name
Sig[3].Value=StackHash_6417
Sig[4].Name=Fault Module Version
Sig[4].Value=0.0.0.0
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=00000000
Sig[6].Name=Exception Offset
Sig[6].Value=0000000001fcfb10
Sig[7].Name=Exception Code
Sig[7].Value=c0000005
Sig[8].Name=Exception Data
Sig[8].Value=0000000000000008
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7600.2.0.0.768.3
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=2057
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=6417
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=6417cb0c225d310e822afe1b225d7e8e
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=4505
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=45059c03f6ad2ef56282147a47c1a995
UI[2]=C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamsvc.exe
UI[3]=NVIDIA Streamer Service has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution (recommended)
UI[6]=Check for a solution later (recommended)
UI[7]=Close
UI[8]=NVIDIA Streamer Service stopped working and was closed
UI[9]=A problem caused the application to stop working correctly. Windows will notify you if a solution is available.
UI[10]=&Close
LoadedModule[0]=C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamsvc.exe
LoadedModule[1]=C:\Windows\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\Program Files\AVAST Software\Avast\snxhk64.dll
LoadedModule[3]=C:\Windows\system32\KERNEL32.dll
LoadedModule[4]=C:\Windows\system32\KERNELBASE.dll
LoadedModule[5]=C:\Windows\system32\WS2_32.dll
LoadedModule[6]=C:\Windows\system32\msvcrt.dll
LoadedModule[7]=C:\Windows\system32\RPCRT4.dll
LoadedModule[8]=C:\Windows\system32\NSI.dll
LoadedModule[9]=C:\Windows\system32\ole32.dll
LoadedModule[10]=C:\Windows\system32\GDI32.dll
LoadedModule[11]=C:\Windows\system32\USER32.dll
LoadedModule[12]=C:\Windows\system32\LPK.dll
LoadedModule[13]=C:\Windows\system32\USP10.dll
LoadedModule[14]=C:\Windows\system32\SHELL32.dll
LoadedModule[15]=C:\Windows\system32\SHLWAPI.dll
LoadedModule[16]=C:\Windows\system32\ADVAPI32.dll
LoadedModule[17]=C:\Windows\SYSTEM32\sechost.dll
LoadedModule[18]=C:\Windows\system32\WINMM.dll
LoadedModule[19]=C:\Windows\system32\VERSION.dll
LoadedModule[20]=C:\Windows\system32\XmlLite.dll
LoadedModule[21]=C:\Windows\system32\d3d9.dll
LoadedModule[22]=C:\Windows\system32\d3d8thk.dll
LoadedModule[23]=C:\Windows\system32\dwmapi.dll
LoadedModule[24]=C:\Windows\system32\IPHLPAPI.DLL
LoadedModule[25]=C:\Windows\system32\WINNSI.DLL
LoadedModule[26]=C:\Windows\system32\NETAPI32.dll
LoadedModule[27]=C:\Windows\system32\netutils.dll
LoadedModule[28]=C:\Windows\system32\srvcli.dll
LoadedModule[29]=C:\Windows\system32\wkscli.dll
LoadedModule[30]=C:\Windows\system32\OLEAUT32.dll
LoadedModule[31]=C:\Windows\system32\POWRPROF.dll
LoadedModule[32]=C:\Windows\system32\SETUPAPI.dll
LoadedModule[33]=C:\Windows\system32\CFGMGR32.dll
LoadedModule[34]=C:\Windows\system32\DEVOBJ.dll
LoadedModule[35]=C:\Windows\system32\WTSAPI32.dll
LoadedModule[36]=C:\Windows\system32\USERENV.dll
LoadedModule[37]=C:\Windows\system32\profapi.dll
LoadedModule[38]=C:\Program Files\NVIDIA Corporation\NvStreamSrv\libzmq.dll
LoadedModule[39]=C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554\MSVCP90.dll
LoadedModule[40]=C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554\MSVCR90.dll
LoadedModule[41]=C:\Windows\system32\IMM32.DLL
LoadedModule[42]=C:\Windows\system32\MSCTF.dll
LoadedModule[43]=C:\Windows\system32\nvapi64.dll
LoadedModule[44]=C:\Windows\system32\mswsock.dll
LoadedModule[45]=C:\Windows\System32\wshtcpip.dll
LoadedModule[46]=C:\Windows\system32\cryptbase.dll
LoadedModule[47]=C:\Windows\system32\DNSAPI.dll
LoadedModule[48]=C:\Windows\System32\fwpuclnt.dll
LoadedModule[49]=C:\Windows\system32\rasadhlp.dll
LoadedModule[50]=C:\Windows\System32\wship6.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
State[1].Key=DataRequest
State[1].Value=iData=1/nDumpFile=//Upload//iCab//f1b7790af80c4eaf8fa296a9d3471ee8-39f6b5eeac33e1e06664ff629eb4b3ab-5--476943682-BEX64-6-1-7600-2.cab/nDumpServer=watson.microsoft.com/nResponseServer=watson.microsoft.com/nResponseURL=//dw//GenericFour.asp?iBucket=-476943682&szCab=f1b7790af80c4eaf8fa296a9d3471ee8.cab&EventType=BEX64&BucketHash=39f6b5eeac33e1e06664ff629eb4b3ab&MID=3304D810-39E2-4F40-A5B0-1CC4A67E5A2F/nMemoryDump=1/nBucket=-476943682/nBucketTable=5/nResponse=1/n
File[0].CabName=AppCompat.txt
File[0].Path=WERBC2D.tmp.appcompat.txt
File[0].Flags=851970
File[0].Type=5
File[0].Original.Path=C:\Windows\Temp\WERBC2D.tmp.appcompat.txt
File[1].CabName=WERInternalMetadata.xml
File[1].Path=WERC015.tmp.WERInternalMetadata.xml
File[1].Flags=851970
File[1].Type=5
File[1].Original.Path=C:\Windows\Temp\WERC015.tmp.WERInternalMetadata.xml
File[2].CabName=WERDataCollectionFailure.txt
File[2].Path=WERC796.tmp.WERDataCollectionFailure.txt
File[2].Flags=851970
File[2].Type=5
File[2].Original.Path=C:\Windows\Temp\WERC796.tmp.WERDataCollectionFailure.txt
File[3].CabName=Report.cab
File[3].Path=Report.cab
File[3].Flags=196608
File[3].Type=7
File[3].Original.Path=Report.cab
FriendlyEventName=Stopped working
ConsentKey=BEX64
AppName=NVIDIA Streamer Service
AppPath=C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamsvc.exe
