Hey guys,
I just decided to blow the dust off my copy of Far Cry to check out the new 1.4b HDR+AA patch for X1800/X1900 series graphics cards. I have installed all the patches, and I am using Catalyst 6.4 display driver and the Chuck patch with ATi Tray Tools to control settings.
I have antialiasing and anisotropic filtering set to application controlled, I have all the image quality settings on high quality, and I have Catalyst A.I. set to high (advanced.) For some reason though, antialiasing will not work in Far Cry if I enable HDR.
I am using the "\r_FSAA 6" and "\r_HDRRendering 7" console commands to enable these settings, and HDR activates but antialiasing does not. I also seem to be getting an odd corruption of mad geometry lines all over the place if I look at a light source (pics to follow.)
I have set my graphics card to stock voltages and clocks to test this.
Anyone have any idea what's going wrong? Thanks in advance for any help.
Sincerely yours,
Exsomnis.
Addition #3: The game works fine when using v1.0 (i.e. no patches) with no problems at all, this leads me to believe that one of the patches is not happy with my hardware. I'm going to have to uninstall them all and install them one-by-one then do a trial run to see which one is the culprit.
Addition #2: This is still happening even after re-installing the game without the 1.4b patch (the one to enable HDR+AA.) This is really beginning to aggrivate me.
Addition #1: I've added screenshots of the corruption below: -
Sincerely yours,
Exsomnis.
