My issue is this the headset works perfect on my ps4 and xboxone and works no issues.
pc creative zxr works perfect within pc but when i put these 2 products together on my pc i get sound loss...
i get stuttering sound that comes and goes and comes and goes.
resulting in breakup in sound also sometimes i completely loose sound and when that happens i get a clicking sound very small in the left hear of the headset... i can reproduce the issue all the time if i go into my sound card control pannel and select : CINEMA then i select Encoder DTS connect, if i do that the issue appears though thats normal cause my headset does not output from the TX transmitter DTS and only does DOLBY DIGITAL so i select that and the sound comes on and works but its like the OPTICAL OUT it switching signals without me knowing or something is happening cause when it starts to stutter and sound loss if i select encoder none then select back to digital 5.1 sound is fixed but then it will happen again its like a bandaid fix.....
its really annoying cause currently i can not use the headset for my pc
only for my ps4 and xboxone :/
