- 21 Jan 2003
- Northamptonshire
Hi Guys,
Bought 2x Asus 4890 TOP cards on sat.
Since fitting into my system, they produce sparlies on the desktop and in games upon boot. After approx an hours of use and the temps warm up abit their fine though
Specs are:
Asus P6T Deluxe
intel Core i7 920 @ 4.2ghz underwater, also tested at stock
2 x Asus 4890 Tops Edition, Temps are fine 60c under load
12gb of corsair ram
3 x 250gb wd re3's in raid 0
1200w BeQuiet psu, more than enough power
all housed in my tj07.
Both cards have been tested on their own and both still show the same issues, my guess is it's a dry joint and when the cards warm up things run fine.
Tested with vista ultimate 64bit sp1 and sp2 also rc of windows 7 ultimate 64bit. Along with cats 9.4 upto 9.7
So im at a loss as to whats causing it. (other than possbile dry joint)
Any ideas lads/lasses?
Specs are:
Asus P6T Deluxe
12gb of corsair ram
