Hi folks
I've finally got my system up and running near to how it should be running, but for some reason, my card temps are very high compared to other peoples + reviews etc
Basically, as I sit here now, my card is idle and has been for around an hour and the temp is 67-68 degrees according to smart doctor. Review suggest it should be mid 40's
To take airflow out of the equation, I have set up a 24" room fan (leaf blower stylee which litterally sounds like a jet) on full whack is making my house shake, and the temps arent shifting. Card is at stock. Anyone else had weird temp readings with their cards? How important is ambient air temp with these vapour chamber coolers?
Its in a pretty warm room, I'd guess its about 24 degrees
Is it worth taking the card out and having a look at it to see if everything is ok?
Bar the temps, the card is sweet. Been playing on mafia 2, dead rising 2, and resi 5 and its smooth as butter with everything on full at 1920 x 1080 res
Thanks
Thanks
