Caporegime
- 8 Jul 2003
- In a house
ASUS is releasing it's own version of the Radeon HD 5770 labeled with Cucore. The Cucore is equipped with a self designed cooler and custom PCB.
ASUS apparently used a lot more copper in the PCB and cooler base plate with the result of 11& better cooling. Unfortunately the clock frequencies remain the same at 850 MHz for the core and 4800 MHz on the GDDR5 memory. Connectivity wise you will spot a HDMI, DVI and D-Sub connector.
ASUS delivers the product with smart Docter software which allows a little voltage tweaking as well.
http://www.guru3d.com/news/asus-radeon-hd-5770-cucore/
, it does look rather good.
