ASUS 5770 fault
29 Oct 2008
I've had a google and I'm having problems similar to this video - http://www.screencast.com/t/FNUOWCO50VF
It seems to show on black areas when viewing video or pictures.
My card is an ASUS 5770, bought from ocuk in Nov '09. Were these 2 or 3 years warrenty? Either way I should be covered, but I think my point of contact after a year is ASUS? Is there a way to confirm that its the card at fault here?
Most things I read seem to talk about the video memory on the card being the problem.
Im running two monitors off this card, the lounge TV and a ZR24W. Only the PC monitor is displaying the problem and not the TV. I've also noticed that I'm getting green dots with the red ones too.
Next step is to rule out the cable and then the port on the card.
You get 2 years warranty with OCUK and 3 years with Asus (if you registered it with them normally you have to do this 30 days after purchase).
It does look like a hardware fault, I suggest you try it out on another PC before you return it.
