Good morning all!
I've been contemplating a new GPU for some time (Replacing a GTX 570), so when Overclockers had the Asus HD7970 Matrix Platinum on offer, it was an easy purcahse despite some concerns I had before hand regarding my PSU (My thought was - may aswell try it with my current PSU before upgrading - All though, it should have been alright)
It arrived today, so I decided to bung it in to my rig - No luck. :
Fans spin (GPU and case), side (Matrix logo) light and the two green lights above the pins apear as expected, but no output what so ever (I can only test the two DVI ports). In addition, having it in my rig prevents it from booting (Mouse lights should appear when you get to the Windows sign in page - they dont. The machine doesnt cut out or restart at any point, just sits about and does nothing of use).
This leads me to suspect a PSU issue. Currently I own (600w, 80+ Gold Rated from BeQuiet):
http://forums.overclockers.co.uk/showthread.php?t=18346669
I'm running: Stock i5 2500k, MSI P67 GD53 (B3) (It only has PCI-E 2.0 slots, but I have been told that 3.0 cards work in 2.0 slots with no real problems?) and some Antec case which is way too small with awful cable management but 4 decent enough fans for my purposes).
I've plugged my 570 back in and everything works fine.
Before I splash out on a meatier PSU, it would be nice to see if the above symptoms correlate to a PSU problem.
Many thanks,
Dan
Many thanks,
Dan
