Hello there,
I have been experiencing an issue when placing my 980 Ti in the PCIEX16_1 lane (specs in my signature).
Up to this point I have been using the graphics card in the PCI-EX16_3 slot where it runs at 8x (not a problem) but since moving from my HAF-X to the 400Q it made sense to place the graphics card in the suggested VGA slot due to the tighter space.
The computer POSTs fine when the 980 Ti is in PCI-EX16 lane 2 or 3 but produces errors during post when the graphics card is in lane 1. The VGA_LED lights up and stays red, then there is a Beep Code error of 1 Long and 3 short beeps (Video (EGA) Display Circuitry error). Also, there is a Error code on the Q-code display of d6 which is "no console device found" error. Oddly even though there are these errors the computer still boots into windows (but with no display output)
I came to the conclusion that Lane 1 was broken so it would be an RMA but I decided to check the lane with an Old Ati 4870. The 4870 worked in all the PCI-EX16 lanes which threw a spanner in the works.
The 980 seems to be getting enough power as the 2 LED indicators show white when the two 8-pin connectors are plugged in. The system is also stable and does not fail during a stress test or gaming.
So it appears that all the PCI lanes are healthy and that the GTX 980 Ti is healthy it's just doesn't work in lane 1. I have reseated the card about 10 times in Lane 1 to no avail.
Any ideas as what could be the problem? Is there a setting in the BIOS that should be changed when using a newer graphics card (than the 4870...)? My Bios revision is: 2001
Thank you for your help.
