- 11 Apr 2016
- London
This card or monitor has developed a fault that ONLY occurs on the Display Port. The monitor flashes on and off? I have switched to HDMI and the display is fine. The card has 2 display ports, but both have the same problem. I have tried the second DP on the Dell Monitor, but same problem? Not sure if it is a fault with the card or monitor? I do not have another monitor with a DP to try. Maybe I should buy another DP cable, as it may be faulty? The card is only about 14-16 months old, and I think it is still under the Asus warranty. This is the first time this problem has occurred.
