Asus A8N32-Sli And Motherboard Monitor Problems
27 Jan 2003
Chesterfield, UK
Hi,
Anyone know if there is a configuration file for this motherboard? I'm not getting any sensors in the drop down list to configure.
I'm using a Orbital display and software in conjuction with MBM to display the temps. Also using MBM in conjuction with Atitool to get the gpu temp. So it would be nice if I could use MBM or is there a better package?
Any help would be greatly appreciated
I thought all asus motherboards come with the utility "Asus Probe" to monitor your system temps and fan speeds... It should be on one of the cd's that came with your motherboard...
Apz that work with the a8n32 temp monitor
Asus probe II
Speedfan
AMD monitor
Everest
All give the same temp/volt readings as the others so all are as 'accurate' as each other'.
