Over the last two days the ASUS Ai Protection on my router keeps getting triggered by my computer trying to access a 'malicious site'. Presumably this is because I have some unknown malicious software trying to access it to download or transmit something.
I have checked the URL in the trendmicro Site safety centre checker tool and it flags as safe. The site has the words Winner and Survey in it so it sounds pretty suspicious right off the bat.
At the moment my router is certainly protecting me but i'd quite like to get rid of the problem; find out what application is making requests to this potentially malicious website.
Would appreciate any help on this as I haven't had to do something like this before.
I have removed my computer name, mac address and the malicous website.
Event number : 1
Alert type : Malicious Sites Blocking
Source : <My PC and MAC address>
Destination : <malicious website>
RT-AC87U's AiProtection detected suspicious networking behavior and prevented your device making a connection to a malicious website (see above and the attached log for details).Suggested actions:
1. If you know that the cause of this attempted connection was a proprietary app or program and not a web browser, we recommand that you uninstall it from your device.
2. Ensure your device is up to time in all its operating system patches as well as updates to all apps or programs.
3. You should take this opportunity to check for, and install, any router firmware updates.
4. If you continue to receive such alerts for similar attempted connections, investigation into the cause will be necessary.
Meanwhile, rest assured that AiProtection continues to help keep you safe on the Internet.
