- 21 Nov 2006
- Staffordshire
Hi all,
Quick question, the asus V2-PE2 barebones is based on the Via P4M890 chipset. On the VIA website it says...
By harnessing the advanced VIA StepUp memory controller technology, motherboards based on the VIA P4M890 can support either DDR or DDR2 memory modules on the same motherboard, providing users the flexibility to use whatever memory standard best suits their requirements.
Will normal 3200 DDR400 work with this barebones?
A quick answer would be really helpful,
Cheers in advance,
John
Cheers in advance,
John
