Hi,
My grandads Asus C223N Chromebook has stopped powering. I done the usual checks for him and it turns out the AC Adapter is fine so its 100% something with the chromebook itself.
When the AC Adapter plugs in the battery light doesn't show.
I tried even disconnecting the battery to run only off AC power but it still doesn't show any life.
The chromebook has two points for the AC adapter, one of them looks damaged. I tried the other one and still no luck so assuming this is some sort of power failure on the motherboard.
Does anyone know what components I should look at to see if anything has fried out that needs replaced? I have a multi-meter and have done some small soldering jobs before, I am just at a loss were to start.
Sorry if this is something that normally isn't posted here I've just used OC for long enough I know 99% of the time I get help no problem (if there is somewhere better to try please PM me).
Thanks
Thanks
