ASUS CROSSHAIR IV EXTREME - INSTOCK NOW!
11 Dec 2005
Cheshire
Asus Crosshair IV Extreme AMD 890FX (Socket AM3) DDR3 Motherboard @ £259.99 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in. In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
The Crosshair Extreme IV motherboard takes all the amazing features and overclocking power of the AMD 890FX Chipset and adds the Lucid Hydra Chip which allows for immense GPU scaling and compatibility. Now you can utilise an Nvidia GPU and ATI/AMD GPU togther in perfect unison for perfect video scaling. The Lucid Hydra chip also allows for GPUs from the same manufacturor to be paired (e.g. ATI 5870 and ATI 5570). Providing unlimited GPU configurations for the ultimate gaming machine.
- AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
- AMD 140W CPU Support
- AMD Cool 'n' Quiet™ Technology
- Supports 45nm CPU
- Chipset: AMD 890FX/SB850
- System Bus: Up to 5200 MT/s ; HyperTransport™ 3.0
- Memory: 4 x DIMM, Max. 16 GB, DDR3 2133(O.C.)/2000(O.C.)/1600/1333/1066 ECC,Non-ECC,Un-buffered Memory
- Dual Channel memory architecture
- Expansion Slots: 5 x PCIe 2.0 x16 (dual @ x16, triple @x16, quad@x16 x16 x8 x8),1 x PCI 2.2
- Multi-GPU Support Support Lucid HYDRALOGIX / ATI CrossFire™X Technology
- Storage: SB850 Chipset: 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10, 2 x JMicron® 363 controllers:
2 x SATA 3Gb/s ports (Gray), 1 x Power External SATA 3Gb/s ports at rear (SATA On-the-Go), 1 x External SATA 3Gb/s ports at rear (SATA On-the-Go)
- LAN: Intel® Gigabit LAN
- Audio: 8-Channel High Definition Audio CODEC
- Blu-ray audio layer Content Protection
- Supports Jack-Detection, Multi-streaming, Front Panel Jack-Retasking
- Supports 1 Optical S/PDIF out port at back I/O
- USB: NEC USB3.0 Controller:
- 2 x USB 3.0/2.0 ports at rear
- AMD SB850 chipset:
- 13 x USB 2.0/1.1 ports (6 ports at mid-board, 6 ports at rear, 1 port at rear is also for ROG connect)
- Accessories: User's manual,1 x I/O Shield,1 x ROG Connect Cable,1 x ProbeIt cable set,1 x 2-in-1 ASUS Q-Connector Kit, 3 x 2-in-1 SATA 6.0Gb/s Cables,1 x 2-in-1 SATA 3.0Gb/s Signal Cables,1 x Multi-functional module (1-port IEEE 1394a + 2-port USB2.0),1 x Thermal Sensor Cable Pack,1 x Crossfire cable,1 x Cable Ties Pack,1 x ROG Theme Label,1 x 12-in-1 ROG Cable Label,1 x RC Bluetooth card,
- Bluetooth Module Accessory Card: Bluetooth V2.0/V2.1+EDR, RC Bluetooth On/Off Switch
- Support Disc: Drivers, Kaspersky® Anti-Virus,ASUS AI Suite II, 3DMark Vantage
- Form Factor: Extended ATX Form Factor
- 12 inch x 10.6 inch ( 30.5 cm x 26.9 cm )
Only £259.99 inc VAT.
ORDER NOW
