Hi
So I've got the Asus Crosshair VI motherboard, and a Thermaltake Core X9 case. The case has 2xUSB 3.0 (20 pin) cables for the front panel, but the motherboard only has a single 20 pin USB 3.0 header.
What would be the best way to connect the 2 USB 3.0 cables to the motherboard?
There is a USB 3.1 header, so I'm not sure if there's any form of adaptor that could be used for that?
I've not had any luck finding either a Y-Splitter cable or internal USB 3.0 hub, and I'd rather not use a PCI adaptor if possible.
Thanks in advance.
Thanks in advance.
