- 31 Oct 2011
- Leyland
Hi guys ive had my Asus 7970 Direct CU ii for a couple of months now and apart from an initial tinker with it in the Asus Tweak software its been running at standard clocks.
However, even if I jam the sliders all the way to the max in Asus tweak it doesn't give that much of a boost.
Im using CCC overdrive at the moment its at 1100/1575 is there anyway I can go further using a different piece of software?
I didn't see much point using afterburner as I believe this card is voltage locked.
Also since I only have a smallish case (300r) im worried about stuffing 2 of these 3 slot monsters in there, what other 7970 would make a good companion for this card?
Cheers.
Cheers.
