ASUS DSL-AC68U/R Firmware version 3.0.0.4.380_4291 (This product supports both Annex A and Annex B)
- Release Note -
DSL:
- DSL firmware updated: v1.0.3.9.
- DSL driver updated - v5.5.2.4.
- Fixed wrong INP value in certain cases issue.
- Added VDSL Stability Adjustment options 2dB and 3dB.
- ADSL WAN (ATM) QIS manual setting list updated.
Add Kuwait ISP Fasttelco
Modify Russia Балашиха ISP Домолинк (0/35)
Add Russia Балашиха ISP Домолинк(35/33)
Add Spain ISP Ocean
Add Turkey ISP Superonline
Add Nepal NTC
Add Germany ISP Deutsche Telekom (VLAN ID 7)
- VDSL WAN (PTM) QIS manual setting list updated.
Add Iran ISP Shatel
Bug fixes and Improvements:
- Added USB modem Pantech UML290VW support.
- Fixed Network Tools not work issue.
- Fixed LAN port cannot be used after disable Ethernet WAN.
- Fixed UI error if port number is out of range in OpenVPN Server Advanced page.
- Fixed setting wrong password while edit an active OpenVPN client.
- Fixed difficult to connect to OpenVPN Server in Load Balance mode.
- Fixed the Main Network SSID display the Guest Network setting after disable Guest Network.
- Fixed the limitation setting of USB disk available size in Time Machine page.
- Fixed Printer monopoly mode FAQ url link.
- Added a FAQ URL link for User Defined QoS Rules.
