Hi guys,
Hopefully some of you can help.
A few months back I ordered an Asus ENGTX 470 (stock clock, stock cooler) from OCUK. I'm having trouble getting a decent overclock from it. The stock voltage it came with is 1.037v and I've managed to get it to 700Mhz on that voltage using MSI Afterburner. I've also set up a custom fan profile to keep the card as cool as I can at full load. Running something like FurMark or OCCT I get a GPU temp of around 77C (still with stock cooler) so I know its not running too hot. However I can't seem to get it stable above that speed even if I give it the full 1.087v available in Afterburner. If I go above that speed, after a few minutes of the test my screen goes blank but the card's fan still whoosh round at full speed.
(Just to note, I haven't even started messing around with the memory clock on it)
Does anyone have any hints/tips/suggestions for squeezing a higher overclock from it? Could it be driver related? I'm currently using 260.99 at the moment.
Thanks
Thanks
, anyways back on topic, i hope that info helps abit.
