Asus fan Expert missing
9 Feb 2004
wales
Hi guys
Just built a system with an Asus rog strix B660 F gaming. I installed AI suite 3 and Fan xpert is missing. I have always clicked on the left hand side of the program and select fan xpert but it’s just not there. Any ideas?
Version 2.00.18
Ah ok so it’s just in the bios now and not in the software?
Q fan controls and sets fan speeds/profiles in the bios , fan expert is software can control in in al suite 3 , not sure why it's not showing up look for expand settings in al suite.
Maybe theres a bios setting
Hi guys
Version 2.00.18
Do you mean B550-F Gaming? If so, I have it there on mine. Your version seems old. I think AI Suite is now 3.01.10 comprising, EZ Update 3.00.16, PPSU (Performance and Power Saving Utilities) 2.00.92 and System Info 2.00.19.
This is the download link to the latest AI Suite 3 for the B550-F Gaming - https://dlcdnets.asus.com/pub/ASUS/...P_EZ_SY_LI_SZ_TSD_W11_64_V30110_20220110B.zip
Maybes try a reinstall?
Did you get this resolved? Replaced a broken fan. Now can’t access fan xpert despite many reinstalls and supposed work arounds. Fans and Water cooler much louder than before
I have a strange issue. My case fans are connected to a Lian Li fan hub which is connected to a fan header on MB. The pump for the custom water cooler (for cpu only) is connected to another header. When I used fan expert everything worked perfectly. Putting things in silent mode stopped all case fans and reduced the pump speed. The mb fan was almost silent. I then installed a new 3080ti and a ASUS Hyper card. The fan on the 3080ti is now quite loud and I cant modify it. I think this is likely due to the Hyper Card leaving not much space between the graphics card and the Hyper Card. All of that I can live with. The interesting issue is that when I use Armoury Crate to control the fans the case fans still stop in silent mode but the pump increases speed. When I use other software (uninstalling everything else) I cant get the case fans to stop nor can i amend the speed of the pump. I have tried using the bios only but the same issue arises
