Asus GTX580 DirectCUII fan issue?
Caporegime
25 Nov 2004
On the road....
My GTX 580 has started behaving oddly, I run GTA V with MSI afterburner running, I have the OSD for monitoring temps, RAM / GPU usage etc.
Having finished my game and checked afterburner, I've notice my GPU fan is dropping to zero briefly and then spinning back up to ~ 60%, you can hear it doing it.
It doesn't seem to do it with any other titles but I can hear it doing the same if I close afterburner prior to launching GTA V so I don't think it's an afterburner issue.
The card otherwise performs just fine, I'm getting a solid performance with V , most settings on high / very high, it rarely dips below 50fps.
Any suggestions?
Up until a couple of weeks ago I was using 2x GTX 580 >>> http://www.gainward.com/main/vgapro.php?id=452
This sounds like something my cards did a lot, the fans are notorious for being on the noisy side and known to fluctuate a lot on fan speeds in certain circumstances.
Say pausing a game or when you hit a loading screen. My cards used to ramp right down for a few seconds before powering back up to under load speeds.
So on the one hand its common on the other there isn't much you can do about it.
Hope that helps.
D,
Thanks for the reply, interesting, I've had the card for a while now but never noticed it do this before and certainly not dropping to zero on the fan speed graph on afterburner.
One thing about the Asus card I have is its fans are very quiet usually, tbh I noticed it via the afterburner graph prior to listening for it, and of course, I'm now sensitive to the sound I guess...
I'll keep an eye / ear on it, I guess, perhaps, it's always done it but now I've noticed it'll just bug me! :o :D
Seems to be doing it a lot more now, fans seem to stop for periods of say 20 - 30 seconds, then they spool up to 80 -100%, temps reduce again and it repeats this cycle, only on GTA V though, tried Crysis last night cranking everything up in the game settings and Nvidia control panel, practical slide show with AA set at silly high, yet the fans were whirring away @40% quite happily.
I'm puzzled!
