Asus K8V SE Raid problem
13 May 2006
Hi folks - begging for help here!
I have an Asus K8V SE running 4 hard drives on a 0+1 raid configuration. Yesterday I got a blu screen and when I rebooted I got the message "Array 1 is offline". When I go into the raid setup (fastrak 378 v 2.01) it tells me that 3 drives have failed. When I look at the drive assignments though it list all of the drives with only 1 assigned to Array 1 - all others being free. I tried disconnecting each drive in turn, the only effect it has is that it changes which drives are free and each has a turn at being assigned to array 1.
One thing I was going to try was to delete the array and re-create it - how to do this though without losing everything?
The board uses a Promise PDC20378 controller chip - I downloaded a set of instructions from Promise and it says you can do it - but "This will not be covered in this document"
Any ideas greatfully appreciated
I'm not sure if this is a m/b or drive problem so I plan to post in the hardrive section too.
Thanks in advance for your kind assistance
