- 22 Apr 2014
This striking looking new AC Router from Asus is the fastest yet and brings some new technologies like MU-MIMO 4x4 antennas. Read more below. We should get stock in on Monday but Pre-Order is available now. I hope to get a sample so I can test against the Netgear Nighthawk x4
Asus RT-AC87U Dual Band Wireless AC2400 Gigabit Router 4x4 MU-MIMO Antenna design @ £224.99 inc VAT
Features:
Fastest Speed. Farthest Coverage. Easy Setup.
Enter a new era of wireless performance with faster-than-incredible speeds, the widest-ever coverage and more control and security than you ever thought possible. RT-AC87U delivers the world's fastest speeds of up to 1734 Mbps at 5G Hz — even faster than tri-band 3x3 routers — plus class-leading concurrent 600 Mbps speeds at 2.4 GHz for an amazing total bandwidth of 2334 Mbps! This means RT-AC87U gives you lag-free online gaming, silky-smooth 4K/UHD video streaming, and effortlessly copes with even the most bandwidth-demanding tasks.
With a separate high-gain antenna for each of the four spatial data streams, this power-packed router gives you true 4x4 multi-user MIMO (MU-MIMO) wireless performance that smokes the competition — and it delivers top performance for all your wireless devices, even those using older Wi-Fi standards. As with all ASUS networking products, you get the very best support with the widest range of device compatibility, plus free firmware updates for years to come — so your RT-AC87U will always be at the forefront.
UNBEATABLE HARDWARE
RT-AC87U is designed for pure performance — as well as its main 1 GHz dual-core processor, RT-AC87U also has a separate dual-core processor that's dedicated solely to 5G Hz 4x4 Wi-Fi related tasks. This means that compared to routers with a single 1.2 GHz dual-core processor, RT-AC87U has Wi-Fi-to-USB transfer speeds that are up to twice as fast3, and can show up to a 50% improvement in total throughput on a heavily-loaded network with multiple clients!
RT-AC87U is not only fast, but looks stunning too. Inspired by the gamer-centric ASUS Republic of Gamers G Series notebooks, RT-AC87U is designed with Stealth Fighter-like curves that exude power and sophistication. It's VESA-mount-compatible too, so you can literally take RT-AC87U to new heights on your wall!
Double dual-core processors-Up to 2X faster USB transfers via Wi-Fi
While RT-AC87U succeeds RT-AC68U's decent USB 3.0 network storage performance, its USB transfer speed over Wi-Fi has been largely improved. When transferring files to and from SuperSpeed USB 3.0 devices over Wi-Fi, our tests3 show that RT-AC87U can be up to twice as fast as a router with a single 1.2 GHz dual-core processor.
Double dual-core processors-Up to 50% more total throughput in busy multi-client networks
In tests4 simulating a heavily-loaded network with three wired and two wireless clients, PCs, RT-AC87U's hardware NAT and dedicated Wi-Fi processor helped it deliver a total throughput (2.4 GHz, 5 GHz and NAT) up to 50% faster than a typical router with a single 1.2 GHz dual-core processor.
Dual USB ports
Share printers, 3G/4G (HSPA+) cellular dongles or USB storage devices over your network! Thanks to SuperSpeed USB 3.0, transfer speeds are up to 10 times faster than USB 2.02. What's more, the ports are widely-spaced for convenient and easy access when using bulky devices — not sandwiched together as on some competing routers. The easy-to-use USB application puts you in full control of tasks for all connected USB devices, including media streaming, file sharing and file downloads.
GROUNDBREAKING WIRELESS PERFORMANCE
Enjoy a new level of wireless performance, with 2334 Mbps of combined 802.11ac and 802.11n bandwidth. With class-leading speeds of up to 600 Mbps on the 2.4 GHz band — thanks to Broadcom® TurboQAM™ technology — and up to 1734 Mbps concurrently on the 5 GHz band, which is even faster than the latest tri-band 3x3 routers, RT-AC87U leaves the competition standing.
At the forefront of technology
RT-AC87U doesn't lead others, it dominates, offering the best current-generation performance for all your notebooks, smartphones and other wireless devices.
UNRIVALED SIGNAL COVERAGE
Boasting a true four-stream, four-antenna (4x4) design, RT-AC87U gives you up to 465m2 (around 5,000ft2) of wireless coverage1. That's 33% more than the latest generation tri-band routers5, making it the ideal choice for large homes and multi-floor buildings. Thanks to AiRadar beamforming and unique multi user-MIMO (MU-MIMO) technology, the more devices you use the more the throughput increases.
Multi-user MIMO technology
The revolutionary and future-proof MU-MIMO technology means that RT-AC87U will be able to connect to multiple MU-MIMO-compatible clients at each device's maximum speed simultaneously, unlike standard single-user MIMO where individual devices have to wait for sequential transmissions. This means that as users add more MU-MIMO-enabled devices, the router's capacity actually increases, giving all users the best possible internet experience.
AiRadar beamforming
ASUS AiRadar intelligently strengthens wireless connectivity using 802.11ac universal beamforming technology, high-power amplification and exclusive ASUS RF fine-tuning. This gives RT-AC87U up to 33% better coverage than 3-stream antenna designs. In real-world tests, RT-AC87U lets you stream two 4K videos flawlessly at its maximum range.
LIFE IN THE FAST LAN
For the fastest wired networking performance, RT-AC87U comes with a dedicated Gigabit WAN port, five 1000 Mbps Gigabit Ethernet LAN ports (one of which can be used as a second WAN port), and hardware-accelerated NAT. Unlike the traditional software-based NAT used in most other routers, RT-AC87U's hardware NAT removes the bottleneck between the wired LAN and the internet, allowing you to get the most out of modern super-fast broadband connections.
Hardware NAT
Removes the bottleneck between the internet and the home network, giving WAN-to-LAN performance that's between 2-5 times faster than a traditional software-based NAT.
Dual WAN support
Configure one of the LAN ports as a WAN to use two internet connections, either to share internet traffic between them or so that one can be used as a backup connection should one connection fail.
TESTED FOR COMPATIBILITY
RT-AC87U, like all ASUS networking products, is subjected to exhaustive compatibility testing during its development. RT-AC87U works flawlessly with a vast range of adapters, media players and other wireless devices to ensure the best performance — it even supports the latest-generation Xbox® One and PlayStation® 4 game consoles.
Powerful online multitasking
With its massive data pipeline of up to 300,000 data sessions, RT-AC87U has around 20 times the networking capacity of conventional routers for exceptionally smooth performance.
Time Machine® support
Supports Time Machine® backups with Apple devices.
WPS
Lets you connect devices instantly with a press of the WPS button.
VPN support
Configure a VPN server or turn your network-connected devices into VPN-enabled clients — with PPTP and OpenVPN protocol support — with no need for paid VPN services or a dedicated VPN server.
Only £224.99 inc VAT.
ORDER NOW
Features:
- Ultra-fast 802.11ac Wi-Fi router with a combined dual-band data rate of 2334 Mbps for smooth up to 4K/UHD video playback, ultra-fast file-sharing of large files and low-latency online gaming.
- World's first 4x4 MU-MIMO antenna design with AiRadar universal beam forming for unrivalled multi-device performance and wireless signal coverage up to 465 m² (around 5,000ft²)1
- Built-in USB 2.0 and USB 3.0 ports for up to 10-times faster data transfers to USB storage devices2, printer sharing, and 3G/4G dongle support.
- Advanced network control.
- Ai Protection with Trend Micro with triple-strength total network security, plus robust parental controls and privacy protection.
- ASUS AiCloud 2.0 lets you access, sync, share and stream your files anywhere, on any internet-connected device
UNBEATABLE HARDWARE
Dual USB ports
AiRadar beamforming
Hardware NAT
Dual WAN support
WPS
VPN support
ORDER NOW
