- 23 Aug 2007
- Rothesay
Ive got a problem i believe with my mobo as it will not allow my cpu to run at anything above a multiplier of 4.
Ive been updating my system over the past 4 weeks or so and as part of it i swapped out my Asus M3A32-MVP for the one in the title.
I run an AMD Phenom II X4 940BE cpu and cool the system with water.
Since swapping the mobo,s ive noticed the new one seems to have the cpu Vcore stuck @ 0.992v so when booting into windows the system downclocks my cpu from what ever i set it in the bios to FSB/HTT x multiplier of 4.
Now i have turned off C1E and Cool & Quiet via the bios and also manually set all the voltages i wish to use, i have also set it to overclock the system by 20% which basically ups the FSB/HTT to 240 Mhz instead of 200 Mhz
So the upshot of this is when running windows i get a core speed of 960 Mhz instead of 3.6 Ghz as no matter what core voltage i set it appears as 0.992v
I have also tried running 1, 2, & 3 core's only to see if it was the cpu at fault but each time it booted with the core's i selected at the same vcore and multiplier.
so is there any other settings etc i could check on the mobo to get this running at full speed, as removing it and swapping back will be a complete PINA.
