Asus M5A97 *mouse not working*
22 May 2011
In the asus bios, the mouse is been a pain, its just stuck in the bottom right corner, everytime i go to move it it shoots back to the corner. Cant really use the keyboard eoither.
Any ideas whats causing it? ive tried another mouse, same result. Both mice are usb, i reckon a normal one would probably work, ive not got one tho. :(
Tally Ho KMP!
Before looking at the hardware side, have you checked the mouse settings in the Control Panel of Windows?
Make sure that the drivers have been installed for your mouse and keyboard.
Cheers
Badger
Tally Ho KMP!
Cheers
Badger
Unfortunately none of that will help the OP to use the mouse in the BIOS as Windows won't have started and no drivers will be loaded.
OP, do you have the latest BIOS version?
