Asus Maximus Extreme Flashing?
Permabanned
26 Feb 2006
I have the Asus Maximus Extreme waiting at home to be built, how do I flash the board I have downloaded the BIOS and the flashing utility from asus.com, do I need to use a floppy disk to flash the motherboard or can I burn it to CD-ROM?
the flashing utility is called: AMI BIOS flash utility (version 2.29)
thanks,
Jack
Use EZ flash (ALT + F2)
Put the file on a USB stick formatted fat or fat32, but note here that some keys just don't seem to appear.
I would burn it to a CD and have it loaded just in case you can't see the USB drive.
You don't need a flash utility with EZ flash, so it's a very simple CD to make.
