Hi all,
Just after some advice, the Maximus Code has two positions for M2 SSD, I am only installing one M2.2280, my question is, does it matter which one i use? There is a horizontal one under the MB cover, or a vertical one which you use with a supplied bracket.
I am using the Intel 600P 512GB that has no heat shield, if that makes a difference.
Any help and advice would be appreciated
Thanks
Thanks
