I have one of these tablets. I dont know why, cos I also have a Tab Pro and a Tab S but there you go!
Anyway, the card keeps on unmounting, and I have had a look on the web but no one seems to be having the same problem as I do.
For a start, the MicroSD is fine. I have tried different cards of different sizes, brands and class, and the card is NOT the problem.
What happens, is that every single time, I try to copy anything at all onto it, as soon as it has finished, the card gets unmounted?
Or rather the PC that is copying the file to it, no longer sees it.
If I disconnect the tablet from the USB port and then connect it back up, there she is! - the file has copied over just fine?
If I take the card out, and use a reader, then I can access teh card just fine and thats what I have to do, to get por... erm, Documentaries onto it.
The Asus Memo read the card just fine too, and I have absolutely no issues what-so-ever and the only time I EVER do have a problem, is when I tro to copy anything to the card, when its in the ASUS?
Anyone know what I can try?
Thank you.
Thank you.
