**ASUS MONITOR WEEKEND ONLY DEALS!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some great offers from Asus on their monitors for the WEEKEND ONLY!!
Asus VS228H 22" Widescreen LED Multimedia Monitor - Black @ £109.99 inc VAT
Delicate touches make a monitor truly great, VS228H Full HD LED monitor, with 50,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. When you would like to watch movies upward lying down, Smart View Technology can adjust color parameters to deliver the same image quality and colors with straight viewing. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
Features:-
- Panel Size: Wide Screen 21.5"(54.6cm) 16:9
- True Resolution: 1920x1080
- Full HD 1080P: Yes
- Pixel Pitch: 0.248mm
- Brightness(Max): 250 cd/m
- ASUS Smart Contrast Ratio (ASCR): 50000000:1
- Viewing Angle: 170°(H)/160°(V)
- Response Time: 5ms
- Display Colors: 16.7M
- Signal Input: HDMI , D-Sub, DVI-D
- Earphone jack: 3.5mm Mini-Jack
- 3yr On-Site Warranty
Was [£119.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Asus VE228HR 22" Widescreen LED Multimedia Monitor - Black @ £119.99 inc VAT
Full HD 1080p Visual Enjoyment Together with HDMI Interface. Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 21.5"(54.6cm) Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.248mm
- Brightness(Max) : 250 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 800000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Video Feature SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 30 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 512.84x385.96x201mm
- Box Dimension(WxHxD): 576x468x148mm
- Weight Net Weight (Esti.): 4.1 kg
- Gross Weight (Esti.): 6.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval Energy Star 5.0, CEL, UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, WEEE, Windows Vista & Windows 7 WHQL
Was [£129.95] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Asus PA238Q 23" Professional ProArt Widescreen P-IPS LCD Monitor - Black @ £199.99 inc VAT
Each PA238Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity. PA238Q adopts 178degrees of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors.
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc.
PA238Q's built-in internal 10-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution. The ergonomically-designed PA238Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position. Picture-in-Picture and Picture-by-Picture allows users to view images from different signals in almost anyway they want.
Features:-
- Panel Size: Wide Screen 23.0"(58.4cm) 16:9
- Color Saturation : 100%(sRGB)
- Panel Type : IPS
- Full HD 1080P : Yes
- Pixel Pitch : 0.2652mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 178°(H)/178°(V)
- Response Time : 6ms (Gray to Gray)
- LCD ZBD Warranty : Yes
- Signal Input : HDMI , D-Sub, DisplayPort, DVI-D
- Earphone jack : 3.5mm Mini-Jack (for HDMI & DisplayPort Only)
- USB Port(s) : 1 x upstream, 4 x downstream
- Chassis Colors : Black
- Tilt : +20°~-5°
- Swivel : Yes
- Pivot : Yes
- Height Adjustment : Yes
- Warranty 3yr On-site
Was [£219.95] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Asus PA248Q 24.1" Professional ProArt Widescreen IPS LED Monitor - Black @ £359.99 inc VAT
Experience professional-grade color fidelity and reproduction with the ASUS PA248Q ProArt series LCD display. Each PA248Q guarantees industry-leading color accuracy, having been pre-calibrated to minimize the color different to ?E < 5 right out of box. The PA248Q delivers 100% sRGB color reproduction on its 16:10, 1920 x 1200 optimal HD A+ IPS panel with 178° ultra-wide viewing angle. It is the world’s first monitor with four USB 3.0 ports, ensuring enhanced productivity thanks to data transfer speeds that are up to 10X faster than Current USB 2.0 standards.
The out-of-box settings are impressive as each PA248Q is pre-calibrated at factory to prove the best color accuracy. To ensure that each PA248Q produces the most accurate and consistent color, we carefully measure its ?E and gamma value and track its gray-scaling. It even supports both Gamma 2.2 for PC and Gamma 1.8 for Mac – offering users more flexibilities to work with. Each PA248Q guarantees industry-leading color accuracy, having been calibrated to minimize color difference to ?E (Delta E) of less than 5 – ensuring precise reading of color input and guarantees excellent color fidelity.
The ASUS PA248Q features a 16:10 aspect ratio, 1920 x 1200 A+ IPS LED-backlit panel for 100% sRGB and 72% NTSC color reproduction; addititionally, along with a 178° wide viewing angle, it ensures quality visuals and minimal onscreen color shift from almost any viewing position. With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 300cd/m² of brightness, the ASUS PA248Q enhances display contrast and sharpness – by adjusting the luminance of the backlight to achieve the darkness black and brightest white – delivering lifelike visuals.
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors. ASUS PA248Q also delivers ultra-smooth visuals thanks to a 6ms (GTG) response time – ensuring users have a lag-free viewing experience when it comes to watching movies or playing games. Games played under the PA248Q are more vivid – as all details can be seen and true color can be shown with the PA248Q.
PA248Q sets a standard by being the world’s first monitor with four USB 3.0 ports; users can easily plug in their devices and experience ultra-fast transmission speeds that are up to 10 times* that of current USB 2.0 standards. An extensive array of connectivity and high compatibility options are available with the PA248Q including DisplayPort, HDMI, DVI and D-Sub; the PA248Q also allows users to use up to two or three displays simultaneously.
With award-winning design, fast response time and advanced visual technology, DisplayPort-ready PA248Q gives you a leading multi-display experience – so you can see all the true color and every detail brilliantly. ASUS Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters according to ensure color accuracy and image fidelity. Six preset modes (Scenery, Theater, sRGB, standard and two user modes) can be selected via a designated hotkey.
The PA248Q has a 5-way navigation key that acts as a joystick that gives access to the QuickFit Virtual Scale function along with all OSD functions and settings. The PA248Q features customizable OSD shortcuts through two designated hotkeys for quick access to the 10 most frequently used OSD functions. ASUS exclusive innovations Picture-in-Picture (PIP) and Picture-by-Picture (PBP) allows users to view images from different signals in almost anyway they want. PIP and PBP let users view images from different signals and let them switch between the main and PIP source, including audio, easily. SUS included its exclusive QuickFit Virtual Scale Function with the PA248Q, allowing users to preview photos and documents on screen in their actual sizes prior to printing. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. Additionally, the PA248Q also comes with a choice of seven different background colors for users to choose from.
Features:-
- Professional-grade color fidelity with pre-calibrated ?E <5 for industry-leading color accuracy
- True, precise colors on a 100% sRGB, 16:10 aspect ratio, 1920 x 1200 optimal A+ IPS panel
- The world's first monitor with four USB 3.0 ports for 10X faster transfer
- ASUS-exclusive innovations like QuickFit, Splendid™ and 5-Way navigation key for enhanced productivity
- A comfortable viewing experience with award-winning ergonomic design with tilt, swivel, pivot and height adjustments
Specification:-
- Panel Size: Wide Screen 24.1"(61.13cm) 16:10
- Panel Type : IPS
- True Resolution : 1920x1200
- Pixel Pitch : 0.270mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 80000000:1
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes
- Color Temperature Selection : 4 Modes
- Color Accuracy : ?E? 5
- Gamma adjustment : Yes (Support Gamma 2.2/1.8 )
- Color Adjustment : 6-axis adjustment(R,G,B,C,M,Y)
- QuickFit (modes) : Yes ( Modes)
- Picture-in-Picture
- Picture-by-Picture
- HDCP support
- Audio Output : HDMI 1.3
- Tilt : -5°~+20°
- Swivel : Yes
- Pivot : Yes
- Kensington lock
- Phys. Dimension with Stand(WxHxD):557.2x416.3x235mm
- Phys. Dimension without Stand(WxHxD):557.2x362.8x62mm(For VESA Wall Mount)
- Box Dimension (WxHxD):681x439x292mm
- Net Weight (Esti.):6.4kg
- 3yr Warranty
Was [OLDPRICE] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Asus VS247H 24" Widescreen LED Monitor - Black @ £139.99 inc VAT
Delicate touches make a monitor truly great, VS247H Full HD LED monitor, with 50,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Features:-
- Panel Size: Wide Screen 23.6"(59.9cm) 16:9
- Full HD 1080P : Yes (support 1080i/p by 1:1)
- Pixel Pitch : 0.272mm
- Signal Input : HDMI , D-Sub, DVI-D
- Earphone jack : 3.5mm Mini-Jack (for HDMI Only)
Was [£149.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
Asus PB278Q 27" Professional LED Multimedia Monitor - Black @ £499.99 inc VAT
Envision bigger with 2560 x 1440 WQHD, packing four times the pixel density of 720p! New premium 16:9 wide-format PB278Q LED displays afford 178° wide viewing angles for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive Splendid Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true “what you imagine is what you create” power. HDMI 1.4, DisplayPort 1.2, and dual-link DVI support WQHD natively, accentuated by room-dominating audio via twin 3W speakers. To help you stay naturally focused, ergonomic design includes tilt, swivel, pivot, and height adjustment, plus streamlined cabling that keeps clutter off your desktop.
The PB278Q features a 16:9 aspect ratio and a LED-backlit 27” WQHD display that provides 109 pixels per inch (PPI), resulting in high quality 2560 x 1440 visuals – equaling four times the resolution of standard 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays.
The screen’s 109PPI density means there are 109 RGB matrices within one inch. Generally, the more pixels a display has, the more lighting (or power) those pixels require to achieve the best visuals. However, with advanced LED backlighting on the PB278Q, power and energy savings are no longer compromised, while better visuals are assured.
The ASUS PB278Q provides an ultra-wide 178° viewing angle on both horizontal and vertical planes, thereby minimizing onscreen color shift even when viewed from extreme angles. With its WQHD display, you enjoy 77% more desktop space than a full HD screen to spread out your windows and palettes. It is also about 25% sharper than a generic 27” full HD display, delivering ultra-smooth visuals thanks to 5ms (GTG) response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. The ASUS PB278Q is undoubtedly your best choice for work and play.
The PB278Q features a host of connectivity options that include HDMI 1.4, DisplayPort 1.2, and dual-link DVI for native WQHD, plus D-sub for full HD 1080p content transmission. Twin built-in 3W speakers provide quality audio for a completely immersive home theater experience.
With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the PB278Q enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
Driven by a precision color engine that automatically analyzes and determines the nature of your current task, Splendid™ Video Intelligence Technology adjusts display parameters accordingly to ensure color accuracy and image fidelity. Six preset modes (scenery, theater, sRGB, standard, and two user-customizable modes) can be quickly selected via a designated hotkey.
The PB278Q offers a highly ergonomic and smart design that comes with tilt, pivot, swivel, and height adjustments to ensure an always-comfortable viewing and usage experience. Its smart cable management further promotes clutter-free spaces for work and enjoyment.
Features:-
- Stereo Speakers: 3W x2
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 8000000:1
- Brightness: 300cd/m²
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI 1.4, 1x DisplayPort 1.2
- 4-Port USB Hub
- 8-in-1 Card Reader
- VESA Compliant (100x100)
- Dimensions: (WxHxD): 643x552.3x218 mm
- Weight: 8.80kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Only £499.99 inc VAT.
ORDER NOW
Asus VG278HE 27" TRUE 144Hz 3D Widescreen LED Monitor - Black @ £359.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278HE. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology*, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278HE is able to double per second to deliver ultra-smooth motion scenes in intense actions, which is over twice faster than generic LCD monitors, delivering ultra-smooth 2D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey.
VG278HE comes with rich connectivity including HDMI 1.4, Dual-link DVI-D, D-Sub. Users could simultaneously connect VG278HE to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players, audio devices and set-top boxes for limitless entertainment with its built-in stereo speakers
Features:-
- Ultra smooth action with 144Hz rapid refresh rate and 2ms (GTG) tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- A comfortable viewing with ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- VG278HE supports NVIDIA 3D Vision 2 through connection of Dual-link DVI.
- Suggest purchasing the additional NVIDIA 3D Vision 2 Kit for immersive 3D enjoyment, also available from OcUK!
Specification:-
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- Pixel Pitch: 0.311mm
- Brightness(Max): 300 cd/?
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 2ms (Gray to Gray)
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard Mode/Night View Mode/Game Mode)
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Power Consumption(Typical): <65W
- Power Saving Mode: <1W
- Power Off Mode: <1W
- Voltage: 100-240V, 50/60Hz
- Tilt : +15°~-5°
- Swivel : Yes
- Kensington lock
- Phys.Dimension with Stand(WxHxD):643x437.8x249.7mm
- Phys. Dimension without Stand(WxHxD):643x385.6x59.5mm(For VESA Wall Mount)
- Box Dimension(WxHxD):732x560x176mm
- Net Weight (Esti.): 8kg
- Gross Weight (Esti.): 10kg
- Warranty: 3yr
Was [£419.99] Inc. VAT
ORDER NOW
Asus VG278H 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £469.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 120 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 120Hz refresh rate and 2ms tracer-free
- Ergonomic design for swivel, tilt angle, and height adjustment
- Pixel Pitch : 0.311mm
- Response Time : 2ms (Gray to Gray)
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- HDCP support
- Tilt : +15°~-5°
- Swivel : Yes
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was [£499.99] Inc. VAT
Only £469.99 inc VAT.
ORDER NOW
Possibly 21:9 2560x1080 120Hz in the coming months.
that could be interesting, but i still think i'd prefer 2560x1440.
when phillips made the 21:9 for home cinema a few years ago it was a bit of a flop, but it just may be better suited to the pc, will have to wait and see
It did flop yes, quite a few are jumping back on 21:9 though, Phillips, LG & dell so far, seems like a better solution for those that want eyefinity and don't like bezels :D
