- 29 Sep 2011
Reading the manual for the ASUS ROG STRIX X670E-E am I right in thinking that if I want to run 3 m2 drives without dropping down to x8 on the PCIe 5.0 I would need to run them in M2_1, M2_2 & M2_4?
I'm a bit confused as the manual states if you use M2_3 the PCIe5_1 drops down to x8 and the _2 drops to x4, but there is also a table that implies if a PCIe card is used in slot PCIe_2 then PCIe_1 is dropped down to x8. Would that not also apply if something is in M2_2 slot?
![manual1.jpg](https://i.ibb.co/jTKCtQz/manual1.jpg)
![manual2.jpg](https://i.ibb.co/56P2Jym/manual2.jpg)
